Yes I did a search first! Question about SLK TSB
1185 5
Hey guys I spent quite a bit of time searching and I am hoping you guys could lend a hand to complete the information on this TSB.
I have a 2003 MB SLK 320 I just bought and it is awesome but the weather has gotten chilly around here (below 55 F) in Jacksinville FL and I noticed much more in cold weather but it does not seem to go away 100% is squeaking/creaking noise from right behind my driver seat. AT first I thought it might be coming from the rear driver spring/shock assembly but after coming the TSB's it seems like TSB P-00_45-77 is the guy giving me the problems.
For refrence this is all I got from ALLDATA:
P-00_45-77 FEB 04 Interior - Squeaking/Creaking Noise Kit
Can anyone give me more info? Has anyone here gone to MB with this TSB for your car? How long to fix? Any hassle getting TSB work done? ANy info at all would help.
Elias
PS just in case people did not have or to lazy to look up here is the alldata for the 2003 MB SLK 320.
Bulletins for 2003 Mercedes Benz SLK 320 (170.465) V6-3199cc 3.2L SOHC (112.947)
Service Bulletins
TSB Number Issue Date TSB Title P-80_00-25 MAR 04 Keyless Entry/Alarm System - Various Malfunctions
S-07_61-039A MAR 04 Engine Controls - DTC Trouble Shooting
P-82_95-305 FEB 04 Emergency Contact/Alarm System - System 'Runaway'
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
S-01_30-15 FEB 04 Engine - Cylinder Wall Damage Assesment
S-49_10-08 FEB 04 Exhaust System - Rattling/Hissing/Humming Noises
P-40_10-43 JAN 04 Tires - Michelin Pilot Sport A/S(R) Tires Not Approved
P-47_10-27 JAN 04 Fuel System - Fuel Filler Cap Hard to Remove/Install
S-18_00-16A DEC 03 Gasoline Engine - Oil Sludging
S-54_21-101 OCT 03 Engine Controls - ECM Flash Process Change
P-82_60-292 SEP 03 Audio System - Volume Knob Damaged
P-07_07-34 JUL 03 Engine Controls - MIL ON/Multiple DTC's Set
P-14_30-15 JUL 03 Emissions - MIL ON/DTC P2003 Stored in Memory
P-82_10-256 JUN 03 Lighting - Condensation In Fog Lamps
P-20_10-23 MAY 03 Cooling System - Water Pump Leakage
P-47_25-27 MAY 03 Fuel System - Knocking Noise at Idle
P-82_70-222 MAR 03 Cell Phone - Phone Won't Fasten Into Cradle Holder
P-67_00-09 MAR 03 Body - Windshield/Rear Glass Body Seam Corrosion
S-07_61-27A MAR 03 Engine Controls - ECM Reprogramming Procedure
P-80_57-20 FEB 03 Audio System - RF Interference Explanation
P-82_62-169B OCT 02 Audio System - Various CD Player Malfunctions
S-82_70-135B OCT 02 Fiber Optics System - Configuration/Version Coding
P-26_50-01 SEP 02 M/T - Assembly Precautions/Recommendations
P-18_00-17A JUL 02 Engine - Approved Engine Oils
S-07_08-001 JUL 02 Engine Controls - Software Calibration Number Coding
P-82_10-196 JUN 02 Lighting - Fog Lamp Bulb(s) Inoperative
S-82_70-179A FEB 02 Cellular Phone - V60 Programming Instructions
Your text here​
Your text hereYour text here
'05 SLK55 AMG
I had a similar creaking noise coming from around the drivers seat...eventually figured out that it was the "female" part of the seat belt buckle rubbing against the seat while it was fastened.
'05 SLK55 AMG
The other main creak I have is coming from that textured metal decklid behind the rollbars. It's worse in the cold, and over bumpy roads...if I reach back and put some weight on it, it goes away. Still need to figure out how to fix it though.
See if either of those are your problems.
2001 SLK 230
http://www.benzworld.org/forums/forums/thread-view.asp?tid=1164383&posts=5&hl=roof+seal+lubricant/
This link will take you to the TSB number and the part number for the lubricant.
Thanks for posting that ALLDATA information. I had not heard of that site until now. Great info.
2003 MB SLK 320
Discussion Starter · #6 ·
Thanks to everyone!
[:D]
I have to say that you can get this info from your cra at ALLDATA (hit ALLDATA and TSB in yahoo) and you should be able to find the link.
Thanks for the ideas and I have to say Dartek it sems like we have clone cars in that on the way home from the club I reached around with my had behind me and laid it out on the deck and that seemed to quite it down by 90%.
The cold thing seems to be the big thing and even when I set the cabin temp to warm as soon as the inside warms up the noise goes way down.
I will also look into the female part of the seatbealt as that could also be something....
Thanks for the link TXmudman I will try that as a last resort before the other two...Since my car is under warrantee I will do that with my service B that is coming up…
I have to say though the MB dealer must have used 87 octante with his full tak of gas as the car was a bit of a slug on warm up at low speed on the first tank of gas but after my 3 tank of Techron 93 octane gas from Chevron the car is just getting faster and faster and IMHO 60 to 80 is done in a blink of an eye...
I can't even imagine the AMG version....
Elias
