I thought I had a faulty relay causing my LR and RF windows to not work. Turns out it was a barely blown fuse. I had to hold it up to the light to see it was not intact.
Anyway, that's fixed, as I have a bunch of fuses I scored at the salvage yard last time I was there.
However, this means I had no reason to disassemble the relay which fits in socket "D". This relay, at least partly, controls the A/C fan. I didn't do anything to it, merely removed the cover, which was destroyed in the process, but IT STILL WORKS 100%!
Gotta love old-style tech, sometimes. The fuse box being nicely sealed means I don't feel terrible about it being 'naked', though I do wish, now, I hadn't messed with it. I mean, after 19 years, it's not even particularly dusty in there, and this was a Las Vegas car for the first 18 years of its life.
One thing I noticed. If the relay is 'on', while the key is out, the fan runs. This could be nice to have on a timer of some sort to clear post-engine-stop heat bulid-up. Probably unnecessary, though.
Does anyone know what each relay controls? "C" and "D" appear to both work the A/C fan, as had the one which is coverless not worked, I would have pilfered one from elsewhere, for a while.... The local dealer is out-of-stock, and I have no reason to go to that side of town, anyway.
I'm also hoping to find a local salvage yard with a couple of these, as, if nothing else, I need the parts to get my sunroof back to tilting. I miss that as a vent when parked, opened just a few mm's.
I was both surprised, and quite pleased, to find the A/C fan on the condenser doesn't run until the engine coolant temp is above a preset level. This rocks, as on the last car I had, a 1999 Suzuki Grand Vitara, turning the A/C on had the fan going full-tilt, even if it were -10F outside. Not particularly smart, IMO, and actually, this behavior cost me a condenser on that car. Small rocks which had made it past both the grille and the fan's grille, flattened every fin covered by the fan in less than 8 seconds. I think, if I'd driven it for three minutes before the fan started, most of them would have shaken out, as the physics are different, being towed behind a motorhome and being driven. Of course, the rock 'drain slot' was smaller than the fan's grille openings...brilliant!!!!
EDIT: While I was under the hood, I snipped the air pump's drive belt, and I'd swear it helps with the stumble my car has immediately after starting, though I need a few more starts to make certain this is the case.
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Here you go:
The pdf doesn't down load. I'll try again later, or PM me with email address.
edit: still doesn't download 45 min later.
The file won't attach to an email either:
Attach Files
There was a problem:
An attached file cannot exceed 10.0MB [What's this?].
Attaching files...
Please wait while we attach the file(s) to your message.
Click "Browse" to select a file. You can attach files up to a total message size of 10.0MB
Sorry man, perhaps someone more computer savy than I can separate the sub file, and attach it.
Its under # 24 - Electrical Troubleshooting,
1986-1991
* Index of Electrical Circuits,
select page: fuse circuit list
You may be able to find it in the forum archive with ,index electrical circuits.'
Man, it must be huge to be more than ten megs...
PDF's are usually pretty good at being small in file size.
Oh, well. I'll look around a bit.
I think Jonathan (jhodg5ck) in Atlanta can help you with the service CD's.
Cheers
