2007 W211 E320 Bluetec OM642
The 2009 B200 Turbo keeps getting code 006B-001, divert air switchover valve jams in open position ( P2261 ) . I've replace the valve, cleared the code and reset ecu with star and code came back.
Decided to change the valve next to the divert switchover valve ( Y31/5 called charge pressure control vacuum transducer) and still keep getting engine cell original code.
Any ideas how to track the issue?
Discussion Starter · #2 ·
Given that the car has had this issue for over a year, should perhaps:
Reserting of mixture adaptation
be the learning process I should execute in DAS xentry? 🤔
The car does seem sluggish on power.
Discussion Starter · #5 ·
Sadly not. I haven't had much opportunity with cold ambient temps so cell is still on.
But at the time of troubleshooting i was wondering if turbo wastage was the issue....
