2004 C-320
I purchased the MERCEDES DUMMY ANTENNA from ebay. I then hollowed out the inside with a drimel tool. In order to get the XM radio antenna to fit right inside the dummy antenna i had to remove the xm commader antenna cover.(you will need a T7 torx screwdriver to remove the screws) I used a high temp glue gun to secure the antenna inside the dummy antenna. I then mounted the antenna using black silicone chalk to the back window of the car, and ran the wire in the groove around the rear window. Once the wire was pushed into the groove it can not be seen. I ran the antenna wire under the trunk molding and back to the XM commander, where it was reconnected. Looks great and i now get a better signal than when it was mounted inside the car.
