You cannot easily open the casing without undoing the glue which holds the plastic to the front of the light, so every change would have to be made through the inspection hatches.
The Xenon (HID) bulb has a different fitting to the standard bulb which I think means that fitting the HID bulb into the standard socket is impossible.
I don't think it can be done.
'12 Peugeot 3008 HYbrid4 (sorry!)
@woz: Original Bi-Xenons is the only way to go - retrofitting Xenon bulbs to non-Xenon headlights is, I'm sorry to put it bluntly: BS
@Benza - and woz: Remember that he's in LHD UK - so he can't profit from the same cheaper sources we do. Otherwise I would of course have tried to pre-sell my DOT Bi-Xenons that will be surplus when my W164 arrives later this year [:D][:D]
Birger
2001 ML 55AMG
Birger - 3/12/2005 10:17 AM
Birger
Actually, he ca get the EURO spec Bixenons. They don't have the amber reflector inside like ours [:p]
Hi, Benza
EUR code Xenons are a lot more expensive new than DOT ones, and even via ebay I guess RHD versions are hard to come by due to the restricted market - that's what I meant to say.
Cheers,
Birger
Hey Woz, if you did the retrofit (which is possible) you may have a problem getting a Mercedes dealer to activate the xenon option in your AAM. Anyways, try and contact Vik on this board (although he is in the process of disowning his ML...) about what he did.
http://www.mbnz.org/forums/view-profile.asp?action=view&uid=275.
He's done a retrofit into his ML - here was a post on trying to get them activated.
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1168773&posts=6&hl=ballast
