1 - 10 of 10 Posts
'01 ML55
I thought that the bulb was tost, so I bought a new bulb, still does not work, also checked the fuse, it's fiine. any ideas as to what the problem might be?
02 ML320 06 ML500
Baring any broken wires,which I doubt, I'm almost sure it is going to be the combination switch.
'01 ML55
Thanks for the reply! I gather that when you say "combination swithch" you are refering to the black control unit that twists on to the back of the bulb?
02 ML320 06 ML500
The combination switch is under the steering wheel. The item with the stalks on either side; it controls the signals, headlights, emerg. flashers and wipers.
'01 ML55
Thanks again for the reply. Do you think that would cause only the one Xenon bulb not to work? the turn signals and both high beams function.
Black 2005 ML 500
Xenon problem HELP
Connect the bad headlamp to the other side and see if it works. Check, too all the connections.. You can compare the wiring connections to the other headlamp.
AC
'03 ML350
You can try swapping the igniter(the one attach to the lamp itself) and see what happens. You maybe able to buy used Hella igniter and/or ballast from ebay for relatively cheap.
'01 ML55
It was the igniter, replaced it and all is good! Thanks for the advice!
hi there i have a same problem on my w208 clk230 2000reg any idea where can i buy the right igniter? a was searching over a week on the internet and nothing :( can u send me on the [email protected] plz many thanks
1 - 10 of 10 Posts
