You will need to replace the entire headlight assembly.shanny64 - 2/24/2005 2:25 PM
Hello,
My headlight is out, and I want to replace it with the xenon ones. Does anyone know how to do this, and parts needed? Will I have to replace the lense?
shanny
Like Greg show in the pictures, THe diffirence between the two is the BI_Xenon works both Low and HI-Beam as a Xenon but the regular Xenon only works on Low Beam.Is the Xenon upgrade plug and play or do I need the dealer to do something? What is the difference between bi-xenon and xenon? Which should I get.
JimB - 2/24/2005 6:15 PM
You have two choices, Do you want Regular Xenon or Bi-Xenon like UncAl have. and what year is your ML430?
welcome btw[]
you can get the regular Xenon here:
http://www.partstrain.com/products/prodpage.html?make=MERCEDES BENZ&model=ML430&year=2000
JimB - 2/25/2005 1:32 PM
It depend where you buying it from. If you are buying it from PP or Performance Product the pig tail is included to be plug and play, but some source may not have the pig tail so you have a problem unless you are some kind a handy man that you can modify your wiring a little, hey it's been done with out a pig tail. Call the source before buying.
Welcome to BW BTW[][
washington dc ML - 2/25/2005 1:40 PM
Thanks, I didn't know what a PIG tail was and thanks also for the welcome. I'm going to purchase an extended warranty prior to making changes to this ML but I've bookmarked the link you provided.
the pigtail looks like this
dewdaltz - 2/25/2005 2:46 PM
