'01 ML55
So I replacet the bullb, there are two wiring harnesses one has four wires and it is obviouis where it plug into. the oth is a brown wire, but I have no isdea where it gos, it looks like it just plugs in/on to something as a ground... Any help would e appreceated
Black 2005 ML 500
In the attached diagram, all #4 are connections that are needed.. Hopefully it will help..
AC
'01 ML55
AC
Thanks AC, I have everything hooked up, but I just don't know where the brwon wire gets plugged into. The connection is a slide on type, I don't see any place where it would slide on to????
Outstanding Contributor
2006 ML500 2002 ML320
Are you just changing a bulb or have you changed over to xenon lights?
02ML320 & 06RClass (sold)
I`ll be changing my xenon bulb soon. Any tips on the replacement. Where did you get your D2S bulb? Thanks.
