'87 300TD, '85 300SD, '84 190D, '81 VW 1.9TD, '93 Chevy 4x4 5sp 5.9L Cummins. '68 Bronco w/4BTA
1987 124 Series 300TD Diesel Wagon.
need the lever arms and levers from 124 series, gas or diesel that will fit.
My valves are there, the other is missing/bad.
Anyone? :bowdown:
Wayne
Discussion Starter #2 (Edited)
Found Them
Was beginning to think I could not find linkages. :surrender:
I was looking for the ball & socket adjustable links that set height from torsion bar to level valves. Mine are damaged and worn.
With one of the links, Went to TWO dealers, and twice order them, only twice to get the wrong part and twice to return the part. :eek:
Two different parts from dealer - they look like links, but one was suspension link, the other ???
Called numerous salvage yards. No links found.
Cannot tell you how many hours I spent on the web searching for the part.
Then just one more Google search, and after a half-hour, there they were, in a picture, with a part number, and I ordered two.
We will see what I get.:rolleyes:
Wayne
About a dozen 1988, 1989, 1990, and 1991 sedans, wagons, 4Matics and 1 coupe
I wasn't exactly sure what you were looking for. I kind of assumed that is was SLS-related. If your latest effort doesn't pan out it may tip me in favor of buying the trashed 88 TE that showed up locally. Parts cars are a *good* thing.
When they arrive
If the links I receive are the right part, I'll post the PN and URL. If not, I'll keep looking. The picture was exactly what I need. We will see what I get.
Waiting.
BTW: was going to replace all four calipers, largely because the L/R was sticking OCCASIONALLY. But the L/F is a hard to get item. After 6 weeks backordered, I cancelled the L/F. I had already replace both rear calipers.
Will return R/F. 1987 and hard to get parts?... Perfect brakes now.
Dealer can get them, but OUCH---the price.
Wayne
Had to Cancel
Emails said the links were going to be backordered, would I be interested in a different brand. I cancelled.
Meanwhile a dealer parts guy sent me a fax with the correct parts listed. So I ordered from the dealer, ironically, the parts were less expensive.
As before; waiting to see what I get.
Will post part numbers if they are right.
Later.
Wayne
Got 'er Done
Order the parts from Valley Motors, Fayetteville, NC.
Received Fedex in 3 days.
Installed - All GOOD, NOW.
1---1230320-14-89 Pull Rod, Tor
1---126-326-15-69 Bracket, Torsion
2---116-328-00-26 U-Bolt
1---126-328-03-27 Lever, Torsion
2---910113-006000 Nut
2---913023-005002 Nut
Case closed. :cool:
