1 - 12 of 12 Posts
99 ML430
Anyone know of someone who is selling these at a good price?.. gotta get my hands on a set soon if I can. PP price is kinda high. Thanks guys in advance
· Member
'00 ML320 Elegance
GOAT - 3/16/2005 8:07 PM
I think that after doing some research, you'll find that PP's price is actually quite low. Your MB dealer will sell the EACH headlamp for what PP wants for the pair! PP's price is roughly what you'll pay for the Bi-Xenon headlamp option, should you be ordering a new ML [:)]
99 ML430
Thanks Drew... I sold my left arm to Supersprint so I guess I might as well sell my right arm to PP's for the Bi-X's... [:D]
· Member
'00 ML320 Elegance
GOAT - 3/17/2005 7:31 AM
Well, not necessarily heh. One way to do it is to have them shipped to Point Roberts or something, or to a friend's place in Seattle. Install them there so you won't have to pay any taxes or duties!
99 ML430
Discussion Starter · #5 ·
Took the plunge today and bought a pair of Bi-X's... I may need you to come install it Drew considerin I got no upper limbs left... haha... will post all pics of mods in next couple weeks when I start slappin stuff on... thanks for all the info Drew [:)]
· Member
'00 ML320 Elegance
GOAT - 3/17/2005 7:48 PM
LOL, I'm sure it can't be that bad. Whereabouts again are you located in BC?
Just ensure that you have your dealership align them properly as that makes a tremendous difference in helping you to get used to the sharp cutoff.
99 ML430
Discussion Starter · #7 ·
I'm in Kamloops Drew... and the dealership here is VERY friendly but they suck technical knowledge and ALWAYS want to charge you for minor stuff... so we'll see...
99 ML430
Discussion Starter · #8 ·
hey Drew do I need to change my fuse to a higher amperage to run the Bi-X's and should I change the bulbs that came with it or will they be suffice?... cheers mate
· Member
'00 ML320 Elegance
GOAT - 3/22/2005 6:38 PM
Yes, absolutely you do need to bump up the fuse (to a 20A, I think?) because you have a pre-'99. Regarding the bulbs, no need to. You have the highest luminal output setup right as it is; allow about 55 hrs for the bulbs to burn in to attain the nice and white colour [:)]
99 ML430
Discussion Starter · #10 ·
Thanks Drew... I thought I had to but wasn't sure of the amperage... is there someone around our neck of the woods that sells the LED front and rear amber turn signals??... that's all I need to complete my lighting mods. And if I read correctly in other posts I only need load equalizers in the front and not the rear correct? I also got some rear braking LED's from Jerry and he said I didn't need any LE's for the back... let me know if Lordco or someone here sells a good set... cheers mate
· Member
'00 ML320 Elegance
Yes that is correct, you will only need the load equalisers for the fronts. Did you get the red LEDs for the brake and taillamps too?
Yes there are LED bulbs available locally, but none that are good unfortunately.
99 ML430
Discussion Starter · #12 ·
hey Drew... thanks for the reply... I just got the brake LED's from Jerry as that is all he had left and is suffice for me... any idea as to where I can order a good set of front and back turn signal LED's with Load Equalizers?... cheers mate
1 - 12 of 12 Posts
