Hi, I just bought Eibach lowering spring for my 300E with series no. 2504 140 but little confuse because i read from the eibach catalogue that for 300E is 2517 140, can I still use 2504 or I should bring it back to seller and replace it with 2517 series???( some of my friend tell me that 2504 can fitted to 300E without any problem,some else said that it can make some problem.....)
please help me:confused::confused: which one is better?:thumbsup: pls share your experience,thanks friend
W124 Moderator
Contact Eibach and tell them of your delima and also tell them about the massive sized wheels and tires. You are going to have some modifictions to do with that much rubber on the car.
Good Luck,
Jayare
93' W124 E36 AMG ; 71' Cadillac Eldorado
2517 140 are the ones which You should go for. 2504 140 are for 200, 200E, 230E, 200D - lighter models. Basically the car may go lower than specified in the springs' description.
thanks, dealer said that 2504 will fit to 300E but as you said the car maybe go lower. any else opinion??
