1 - 14 of 14 Posts
1991 560 SEC Black/Black
Good afternoon you all,
I am in the process of rebuilding the top of my engine and I want to take this assembly completely apart and redo it and I don’t know what it’s called. I am also going to remove the wiring from the assembly and in case it in some shrink tubing, is that a good idea or should I just tape it
thank you
Automotive tire Gas Automotive lighting Rim Metal
Automotive tire Motor vehicle Automotive lighting Bumper Automotive exterior
Automotive tire Motor vehicle Gas Art Wood
Crankset Automotive tire Vehicle brake Bicycle tire Bicycle chain
Yes it has ASR.
The attached picture of the cut sheet that Mercedes Benz gave me associated with this assembly does not match up for some reason having trouble identifying some of the components as I compare them to the cut sheet. My real question is I intend on taking all this apart sandblasting it and having it CROMATED as I am doing with all of the other associated parts for the top of my engine. If I do have them cremated will all the plastic grommets that are on these particular pieces get ruined.
Outstanding Contributor
1989 560SEC, 1989 560SEL, 1995 E420
Yes it has ASR.
As to your concerns about chromating, that seems like a question for your chromating specialist.
Discussion Starter · #7 ·
Thanks for your reply lucky Mike,
I took a search on eBay or this particular part number and you hit the nail right on the head. The line line thank you so much for your input
Automotive lighting Motor vehicle Font Gas Audio equipment
1989 300SE 247k+ miles
Thanks @luckymike! I stared at the original post for a good 10 minutes this morning. Thinking, it looks like the throttle linkage. But it can't be. That's too easy. And wth is all that wiring doing there? Is it some sort of weird cruise control unit????
Discussion Starter · #10 ·
Thanks for chiming in ISTHENWE This is the part number that’s stamped or raised if you will, on the main housing of the unit that has all the wires in it mercedes benz 006-542-85-17. I googled it and eBay and that exact picture came up so whatever it does I’m sure it did it well when the car was new and hopefully it’ll work again when I put it all back together again.
Once again thanks for chiming in
Discussion Starter · #11 ·
If anyone has an electrical diagram this it would mean a lot to me when I put this back together I just wanna make sure I understand what this particular unit does in the car.
Moderator
1987 & 1991 C126
WOWOOOOOOOO
WAY MORE THAN I EXPECTED !!!!
you da Man !!!
Thanks! Glad it works for you man!
I referred to them when I installed Tempomat/Cruise Control in my '91 SEC.
I was very pleased to find ASR 'pre-wired' for the switch.. so the little pictorial gaposis on page 149/1 was of no consequence.
M
1 - 14 of 14 Posts
