1 - 12 of 12 Posts
05 500
I like the newer rear wipers - sleek, more Aero-D and all. Are they a simple plug'n play hardware?
2002 ML55 AMG, 2005 Chrysler Crossfire Coupe Limited, 1999 C280
Good question and I agree with you - So much nicer.
Let's hope someone gives a definitive answer soon.
My R-Class and S500 have the new Aero-D wipers, they use a totally different arm. I'm sure you can retrofit the arms to make it work but would cost you some money. The new Aero-D wipers are so simple to change, you can change it in like 2 mins. You simply lift it up, turn the arm to one side and take it out. Its much better design then the old ones.
^^^ +1
I have the ICON's on both ML's, front & rear. Also on my 190E
I also modified the wiper arms by removing some of the curve so the arms fit flatter against the ICON blades. Looks much nicer than the arms sticking way up above the blades. If you do this don' go too far since you still need some flexibility for the blades. Down side, the original blades will no longer fit the arms unless you restore the bends.
Mike
Hello Mike,
Where online can one purchase the ICON wiper for the rear windshield?
I couldn't find them in Witek's link.
2000 ML430 SOLD, 2007 BMW 328i Coupe, 2014 BMW i3, 2019 Honda Odyssey
Doesn't Bosch have the Hindsight model for rear windshield applications? I don't know what's different about it...
2001 ML430 Sport bought in very nice shape despite 156K miles in August 2010
Bosch Icons front and rear on my 2001. Perfect fit, and a much better look.
I used the Bosch 417A 17" on the rear.
Since Bosch is in Europe you may want to check Euro sources for this blade unless you still have your shipping contacts in the U.S. I would think Bosch would have sales outlets in your area.
I just checked and the 19", which is 1" longer on each end from center, puts the blade above the glass in the center and on to the metal body work. It may just float over the body but I wouldn't want to take a chance of abrading the paint. The grit on a dirty window is like sandpaper.
---------Just a thought -----------
Mike
Amazon.com: Bosch 417A ICON Wiper Blade - 17": Automotive
Mike
Good thought; thanks Mike.:thumbsup:
I think I'll purchase the 17" ones.
1 - 12 of 12 Posts
