190e 2.3 16v
Hi everyone.
The previous owner put this wood trims in the car as you can see on the pictures,
As you guys can see on the first pic, the wood trim has come off and all this glue are stuck there, not attractive. Is there any product out there that can clean it off. Also the one on the dash, I want to removed them but all the glue mark are stuck there, is there any way to get rid of the glue mark or should I just buy some new wood trim and stick them on. If that is the case, where can I buy them? I am in Australia by the way.
One last question relate to the mirror, as you can see, bird poo did some nice damage to the car, what can I use to fix that up.
'85 2.3-16 '99 C280 '11 GLK350
Here, "Up, Over" there's a remover called "Goo Off" that is a liquid that might help. 3M also makes a "Trim Adhesive Remover"
As for replacements, have you contacted Fendertrim or Carshine in Australia?
1992 190e
Believe it or not WD40 (all natural ingrendents) will remove it with out any damage, both glue and poo.
