Hello
First post so be gentle !
As above wiper problem , started with the intermitant not going on till you put onto full wipe then put down to intermitant , tried sawpping over a relay , but not any better . Its now that to get any wipers i have to put onto fast wiper then adjust.
Some times they work on main wiper or intermittant some times not
Is it a whole new wiper/indicator stock i need?
anyone got/had similar problem
Update
Update,found a second hand ML"270 one on fleabay and swopped them today
Nope no still same problem HELP ANYONE !
· Outstanding Contributor
2006 ML500 2002 ML320
Since you already replaced the combination switch, the only other thing it could be is the AAM which controls the intermittent wiper phase..
When the problem occurs, remove the fuse/relay module (steps 1-3 & 5) and with the rubberized handle of a screwdriver, tap the sides of the AAM, or squeeze the sides, and see if the intermittent wipers work.
