21 - 33 of 33 Posts
1993 230 TE.1999 om 606 td. and 722.6 3.2L,clk w208 1987 Kit car with 260e running gear.
Jason do you mean the motor was replaced?
1989 W124 260E
Jayare sorry to hear you have been ill .And also that you are old as the hills haha I hope you will soon recover and be able to do what you want to do ..
W124 Moderator
I'll remember the age comment plink!
Sent from my XT1710-02 using Tapatalk
Current, 90 300CE, 92 400E (Sold 95 E320,70 250C, 91 190 2.6, 91 420 SEL, 95 300D, 87 TD)
Jason said window wiper , and not the screen Jason is that mono wiper the one that came off your car ?.if so the wiper was replaced wrong .
Is it possible to replace it wrong? I have my doubts. I think it's a right hand drive wiper assembly.
W201 Moderator
89 190E2.6- 5-speed Manual, 95 E320 Sportsline-sold, 2001 E320 4matic Wagon-sold
Well it would make sense to design it so that it can rest either way. That way LHD/RHD would not need different parts. Perhaps it is an option in the installation?
Like some kind of switch to tell the system when to stop?
I have had a 124/201 for 31 years straight now and never had to open up the wiper driver so I have no idea how the mechanics of it work, I just think they are cool.
W201 Moderator
It's been a very difficult month for me. I was hospitalized for 4 days at the end of May while my wife and I were at our summer home. I only got worse, so we returned to our Florida home and..here I am again in the hospital.
Blockage in the small intestine. I've lost 25 lbs in 4 weeks and weigh under 150 now. Less than I did in the 6th grade - almost 60 yrs ago. Being discharged tomorrow and will be on the gain weight train for a while.
Jayare
Wishing you a speedy recovery Jim. Get well soon....
Could you just (for example) put the red wire in the black spot and the black wire in the red spot? Bam! backwards operation?
1990 Benz 300E 2.6 (mine) ; 1994 E320 Wagon (wife's) ; 1993 300CE Cabrio, needs some TLC
as it set up, it's stopping on the right side. It should be stopping on the left side which would be with the crank arm 180° the other way and then it would be turning the other direction first so that the arm would go across and then back. The only way I see it could be the way it is, is either it is a right-hand motor, or it was misassembled with a crank 180 out of phase and the motor wired backwards. Hard to say. does the wiper properly extend in the corners and retract as it goes across the middle and then extend in the other corner and then retract as it goes down?
'92 W124 230E Auto
This article should provide the info you require, but ultimately the "MB Mechanic" should correct the problem.
1989 190E sportline
I completely refurbished my MonoWiper a few months ago, and learned that you can easily change the starting position with slightly different assembly. Some race car drivers have them in the middle of the windshield on purpose.
This can be done by loosening the nut no. 6 in this image, repositioning the mechanism and tightening the nut back again.
91 500SL 37k,90 300SE sold, 91 300E sold , 92 300E137k ,02 Kia Sedona ,I know..... its a Mini van.
Jayare
Feel your pain! last August I had a on and off fever 100F- 102 for a week, finally went to ER, turned out to be a baseball size abscess on my colon! it blew my colon up big time, it let loose killer germs into my bloodstream, I woke up the next day with with a nasty 12 inch incision from belly button down to my pubes, and a colostomy bag on my left side! hospitalized for 8 days, then 2 months later they did a reversal of colostomy, 5 days more in hospital, I'm 6'3" 200lbs, went down to 165lbs, gained it all back and life is normal now.
Eat ice cream!
Feel better man.
21 - 33 of 33 Posts
