1 - 1 of 1 Posts
'84 300SD '91 300CE '95 SL500
The other day my wiper just quit in mid-stroke. I could hear a "whinning" noise and new the motor was probably still good. Today I checked it out. As you turn the wipers from low to high you could hear the whin get louder
Then I checked the fuse. A visiual inspection showed the fuse was still good. But just in case, I went ahead and replaced the fuse and made sure that it had goo contact. Sure enough, the wiper now works perfectly.
Just thought I would pass that on in case someone else ever had the same problem. Just because the fuse good ok doesn't mean that it is.:D
1 - 1 of 1 Posts
