2005 G500, 1995 E300D, 1987 560SL, 1997 Porsche 993 C2S, 2011 LX570
Just one for future searches.
When I used the wipers on my G500 2005, it would make a lot of banging noise, as well as not returning to it's proper horizontal position when off.
(This truck is relatively new to me)
I have repaired it. Strangely, the 3 bolts holding a plate to the motor had completely come loose and fallen out. Strangest part of this is that the truck was purchased from West TX, where it rarely rains. Clearly these bolts worked their way loose over a long period of time. I realized that the motor was simply not attached to the vehicle and had tons of free play.
DIY tips.
First, the WIS procedure is somewhat helpful. All of the work can be done from the engine side of the firewall. There is very little room to work from the driver's footwell - and it isn't necessary. The wiper motor is located behind the differential lock actuators on the firewall - driver's side. There are three nuts (10MM) that you can remove and push the actuators and hoses out of the way. Be gentle as to not disconnect anything. WIS suggests disconnecting everything. Completely unnecessary.
The wiper motor is easily removed with 3 10mm bolts. There it is connected to the wiper arm assembly. Just pry a screwdriver in there and separate the motor from the assembly. It is a ball joint and pops out easily. Manually moving the wiper arms can make this easier to access.
Unplug the motor's electrical connection - and the motor is in your hands. The three bolts attaching a plate to the motor are what came loose on my G. I replaced them and used locktight to prevent them from getting loose again.
Re-install in the reverse order. Reconnecting the ball joint on the wiper arm assembly was easy using channel grips.
ONE NOTE: WIS suggested turning the wipers on for one cycle before fully re-installing. I tried and it appeared that my motor was dead. I went through an hour of attempting to diagnose the issue, including hunting down the fuse. Turns out the button that is depressed when you close the hood (probably for the alarm) must be depressed for the wipers to work. Hood up - wipers don't work. Doh!
This is a fairly easy project. And my wipers are perfect now!
I hope that this helps someone.!
DIY tips.
