I recently had the rear end changed out, so I had a chance to see my 2002 ML55 from underneath and I was surprised at how much rust there was.
I just spent the morning wire brushing and undercoating where I found the rust. Nothing is compromised so it wasn't that bad, but it was fair warning that something could develop later on if not taken care of.
I went through 6 aerosol cans of 3M spray undercoat to get into every nook and cranny I could see from underneath.
If you're in a climate that is expecting snow, I suggest you get under your car before the season gets underway and at least check it out:
Would a "rust-stopper" paint work as well or is the undercoating the preferred product? Lots of surface rust on the frame but I have been getting regular maintenance items out of the way. Front brake pads today, hopefully rears on Tuesday.
Nope, my daily driver S600 sedan is black, my ML55 is silver. Always was.
I used a 3M product to do the undercoating. Wire brush off the rust and spray the metal. It's a rubberized coating that I'm told works quite well. I was surprised at how much of the underneath had a superficial coating of rust, it seemed all of the bottom need to be sprayed. It took 6-cans of the stuff to get it all!
Look out for overspray. If you do, brake cleaner will get it off.
