W203
16"
205/55QR16 BLIZZAK WS-50
16X7.5 steel wheels
wheel covers
new lug hardware
$636.00
205/55QR16 ARCTIC ALPIN
16X7.5 Mille Miglia BELLO Alloy wheels
new lug hardware
MB center caps
$908.00
W208
Blizzak LM22's for the OE wheels
$640.00 plus shipping
16" Steel wheel package
215/55HR16 DU WINTER SPORT M3
16X7.5 steel wheel
w/ hardware and wheel covers
$632.00
17" Alloy package
225/45HR17 PIRELLI W210 SNO SPORT
17X7 Sport Edition FOX 2
w/new hardware
$1212.00
W209
225/45HR17 MI PILOT ALPIN
17X7.5 AMG Styling 3
$2000.00
W211
16" Alloys
225/55QR16 MICHELIN ARCTIC ALPIN
16X7.5 MILLE MIGLIA SPIDER II
w/ new hardware
$1032.00
17" Alloys
245/45HR17 DUNLOP WINTER SPORT M3
17X8 BORBET TYPE-E
$1256.00
these are just some suggestions
they are ready to install when they arrive to you
all packages come mounted, balanced at no charge
If Mercedes Center caps fit the wheels we will include them at no charge
If new hardware is required it will be included at no charge
In order to assure customer satisfaction, Tire & Wheel Packages purchased at The Tire Rack are tested before shipment – at no additional charge to our consumers – using the Hunter Engineering GSP9700 Vibration Control System to evaluate and eliminate nearly all possible wheel- and tire-related vibration causes.
The GSP9700 Vibration Control System used by The Tire Rack’s service specialists to finish Tire & Wheel Packages goes far beyond the traditional capabilities of a wheel balancer. In addition to rectifying the inevitable wheel and tire imbalance, the GSP9700 Vibration Control System also "road tests" the mounted assembly to confirm virtually every aspect of a tire and wheel combination that might contribute to a vibration.
The GSP9700 Vibration Control System includes Hunter's exclusive Road Force Measurement System to help detect potential tire uniformity causes of vibration that are not balance-related. This system utilizes a "road roller" which applies up to 1,400 pounds (635 kg) of force against the wheel and tire assembly to measure their combined uniformity. This simulated road force test helps verify if the assembly is "round� when rolling under load.
The GSP9700 Vibration Control System can also measure lateral and radial rim runout (out of roundness or side-to-side movement) to identify and separate wheel runout from tire runout. The system then calculates the contributions of the wheel and the tire to a potential vibration and presents the service specialist with easy-to-follow instructions on the appropriate corrective actions.
If the wheel and tire are at the edge of acceptable tolerances, Hunter's patented ForceMatching(TM) feature is used to align the high point of the tire with the low spot of the rim. This helps maximize ride quality by minimizing the effects of tire force variation and rim runout. If a wheel or tire is found to be out of tolerance, it is replaced with another wheel or tire that is within tolerance.
Once acceptable uniformity has been confirmed, or corrective actions have been completed, the technician can continue with precision wheel balance.
individual winter package selection ... click here
http://www.tirerack.com/a.jsp?a=CQ4&url=/winter/index.jsp
interested in how a particular winter tire did in our testing ... click here
http://www.tirerack.com/a.jsp?a=CQ4&url=/tires/tests/testSearch.jsp
if you have a question regarding a specific package please post it in this thread or give me a call
16"
16X7.5 steel wheels
wheel covers
new lug hardware
$636.00
new lug hardware
MB center caps
$908.00
W208
16X7.5 steel wheel
$632.00
17" Alloy package
w/new hardware
$1212.00
W209
$2000.00
W211
16" Alloys
w/ new hardware
$1032.00
17" Alloys
17X8 BORBET TYPE-E
$1256.00
