1 - 13 of 13 Posts
2000 E320S4M
Has anyone used these before? I was thinking about getting a set in a 255/60/17 for the ML320 since the Dunlop SP 5000 aren't going to cut it in the winter, even with the all-wheel drive, and we want to keep the shinny side up.
Here are some of the specs:
* Premium performance in all weather conditions.
* Directional tread pattern, high-density siping and undeniable precision for luxury cars.
* Maximum responsiveness and handling in adverse weather conditions.
* Porsche-approved for 100% of their current vehicles Winter tire needs.
* Factory-recommended by Audi, BMW, Mercedes-Benz and Volkswagen.
* Rubber Manufacturers Association (RMA) rated for SEVERE SNOW CONDITIONS.
I am thinking that they can't be a bad tire. Does anyone have any experiences with them
300CE, NSX, Miata
am considering these as well for 300CE
am considering these as well for 300CE for Chicago-area winter use
Choosing between this and Bridgestone Blizzak WS-50
The test comparison data (from tirerack.com) is interesting:
- Dunlop has higher speed rating (H vs Q)
- Dunlop has better handling and dry traction, comfort, noise, wear
- Blizzak has better snow (and presumably ice) traction -- although Dunlop is NOT bad
Blizzak WS50 or Dunlop Sport M2 -- for Chicago, seems like Dunlop may have the edge. For a more snow/ice area, definitely Blizzak WS50
Any first-hand experience with these on a Benz ??
BenzWorld Tire & Wheel God
you are comparing an apple to an orange ...
Winter Sport M2's should be compared with
Blizzak LM-22's
I would recommend the Blizzaks over the M2's but, the M2's are pretty good
2000 E320S4M
Can the LM-22 be had in a 255/60R17 size?...
Re: Can the LM-22 be had in a 255/60R17 size?...
the only winter tire available in that size is the Winter Sport M2
Sorry
Luke
2000 E320S4M
No problem Luke. I am going to get a set of 4. Unfortunately duty and exchange makes i...
No problem Luke. I am going to get a set of 4. Unfortunately duty and exchange makes it too expensive to order from the TireRack.
I suggest Canadians order from www.tiretrends.com Great service and excellent prices!
300CE, NSX, Miata
Re: apples or oranges ??
Winter Sport M2's should be compared with Blizzak LM-22's
I guess my REAL question is:
For MBZ E-class in CHICAGO winter, do you suggest a "snow/ice" or "sport winter" fitment ??
Snow/Ice includes: Blizzak WS-50, Michelin Arctic Alpin, etc
Sport Winter includes: Blizzak LM-22, Dunlop Winter Sport M2, Michelin Pilot Alpin, Goodyear Ultra Grip Ice, etc
In Chicago I typically recommend Sport Winter tires because even though you occationally...
In Chicago I typically recommend Sport Winter tires because even though you occationally get heavy snow, mostly your driving on lightly covered roads or wet roads and the sprt tires aere a little more versatile in those types of conditions
300CE, NSX, Miata
Re: In Chicago I typically recommend Sport Winter tires
Thanks Luke... that's what I had concluded, based on reviews, etc.
Am choosing between Dunlop WS M2, Goodyear Ultra Grip Ice, and possibly Blizzak LM22. Pirelli W210 is too $$ IMO.
LM-22's
Pirelli w210
Pilot Alpin
Winter Sport M2's
is the order I would put them in
LM-22's
Pirelli w210
Pilot Alpin
Winter Sport M2's
300CE, NSX, Miata
Re: LM-22'sPirelli w210Pilot AlpinWinter Sport M2'sis the order I would put them in
LM-22's
Pirelli w210
Pilot Alpin
Winter Sport M2's
The Customer Survey data on TireRack website suggests that the Dunlop is a pretty good value, and a great all-around tire.
Blizzak LM-22 ($123) : best in Snow Traction and Ride Comfort (tie with Michelin)
Pirelli Winter 210 ($150) -- good Handling, best in Wet Traction
Michelin Pilot Alpin ($125) - best in Ride Comfort, Noise Comfort, and Wear
Dunlop WS M2 ($114) : best in Handling, good in Snow Traction, Noise Comfort and Wear
note: Bridgestone, Dunlop and Michelin tie for Best in Dry Traction
300CE, NSX, Miata
Re: In Chicago I typically recommend Sport Winter tires because even though you occationally
Would this be true for a heavy RWD vehicle without traction control ?? My fitment is a W124 coupe -- with ABS, no ASR/TCS.
for a W124 I would put them in the previously mentioned order
1 - 13 of 13 Posts
