1985 380sl
Hey team! Any tips on removing the entire wing vent window on my 1972 280SE 4.5? I’m removing the old dry seals and replacing with new. Thanks!
68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
I think you are going to have to take the entire door apart- remove window, rear track, weatherstripping to then be able to unbolt and withdraw the wing window and track. You may or may not be able to reuse the window channel depending on how easy or hard it is to get out.
