280 SE 1976,S 600 1985,190E 1992,300 SDL 1986....And yea there are more to come.Stay tuned!
Gentleman.
Why is it that the windshield wipers stop right then and there when I turn the switch off?:confused:
It does not happen all of the time but it happens too many times.:(
Cheers
· Super Moderator
1986/1990 W126
Yeah thats a strange one. Could be a relay i suppose, but i dont know where it would be. So they work ok, its just the bit that tells them to 'park' doesnt do its thing?
1997 SL320; 1991 300SEL; 2003 ML350
Mine were doing it too. I removed the relay from the fusebox and cleaned the connectors with contact cleaner and a brass wire brush. After re-installing the relay they now work as they should. I don't have a diagram of the fusebox with me here at work, so I can't tell you which relay it was, but do a search of the forum. There is a diagram floating around that shows the function of each of the relays in the fusebox.
Adios,
Mike
