1994 Mercedes Benz E420
Ok, new gremlin to deal with...Now the windshield wiper doesn't work when you push in on the lever to activate the sprayers. Otherwise the wiper works fine. I have a receipt for a new wiper motor, purchased in 2010. It used to work with the sprayers until this morning...any ideas?
Could be as simple as the stalk button being bad. Are the sprayers still working when you push the button???
Also check to make sure your car has the updated copper core fuses. Replace all fuses if needed for less than $5 for a complete car fuse kit.
You should be able to hear it 'trying' to pump fluid, if the fuse and circuit are sound. So if you hearing it trying to pump...just check to see if the front nozzles are clear. I've seen people wax right over them. Work back until you see fluid moving...like the first tubing connection there at the hood.
If you don't hear anything than you have a bad pump or stalk electrical problem....as was said, check your fuse first! You can always test the pump by putting straight 12v into it.
Kevin
