1995 500 sl
'95 500sl, purchased a replacement wiper blade that was too long. got the wiper in a bind at the end of the wipe. probably broke something in the unit. can I get to the linkage? or electical connections or I am Doomed to purchase a new unit? what is the smallest piece I can buy?
· Greek God of the R129
SL500-500SEL-190E
There is a plastic half moon gear that makes the wiper go up/down.
You can find that gear on ebay is the same gear for the 124.
I think that odometer gears has them too.
About $100.
Now buy an I think working from memory 13"by 11" blade, not a 24" strait.
Regards,
aam.
You memory is pretty good.
While our car has a 24" wiper, it needs an off-center mounted blade with the top part no longer than 11" or it will hit the A-Pillar, so it is a 11"+13"=24" setup. Or an 11"+11"=22" center mounted one will also work as the 'short' end would be at the bottom and the non-wiping area would not be in your line of sight.
Or you can keep the OEM Arm and just replace the 24" rubber insert (and save some money too).
SL500, GLC300
that is the best way, it is what i do.
