Crazy problem, but it's seriously annoying. The nozzle that's sprays windshield washer fluid right infront of the drivers line of sight is set way too high up. So it sprays the top of the car. I get more fluid on my side of my window from using the headlight washers!
I looked under the hood and did not see any direct access. Is there any panels on the underside of the hood that gives access or any such things? Also It doesn't seem like you can just simply move the little squirter around. It's secure.
Thanks!
C220 CDI T A & A200 CDI A
Raceit - 2/1/2005 4:41 PM
...The nozzle that's sprays windshield washer fluid right infront of the drivers line of sight is set way too high up...
Can't you aim the nozzles with a needle, like in a W124? Stick a regular needle to the nozzle and turn it to point to a better place on the wind screen.
Duh. I feel silly for asking now. I was close...I was pushing on the black part surrounding the nozzle and obviously that doesn't move. Some times I try to over complicate things.
Thanks!
