Windshield washer NO Squirt DIY
1871 Views 24 Replies 4 Participants Last post by  springerfever
Wife comes home tells me the windshield washer is just dribbling fluid.. Pump motor is good, pull the line and I can't blow through it.. Put a garden hose on it.. and it's still just a dribble.. I try for about hour,. trying to flush the line.. Still I'm getting no where.. I don't want to pull the cowl.. so I just pull up the rubber seal, lift the cowl enough to pull the line up and see what looks to be a small filter right next to the first spay nozzle.. It's not a filter, but a check valve.. at any rate, it was clogged up.. It comes apart easy enough.. so you don't have to buy a new one.. and the best part, you don't have to pull the cowl off to get at it.. So if you've been putting off, fixing your washer.. no need to..
21 - 25 of 25 Posts
Now Wallyo,.. you must understand.. That;s for Timothy grass only.. At $25 a pop, it deserves a nice ride
We/ she grow 57acres of alpha not sure what it selling at this year?
2633756
Bobby, how does one go about leading horses out of the pasture with the ML ? Are you just kind of towing them very slowly ?
Yes, that was the purpose of the back bumper guard that I added a couple of months ago..
And double YES.. on MR ED.. The wife's got ED on 24/7 for the "boys"..
WOW... 57 acres... nice.. We only got 16.. and only about 7 of it's pasture..
As I said it is long story, just don’t want to give impression it is all hers she owns 1/4. So about even with you.
Was her grandparents then dads and uncle’s. Then cousins and dads......
Was about 120 at the start.
But that is small for around here.
21 - 25 of 25 Posts
