1 - 9 of 9 Posts
1995 E320 Sedan
My washer fluid lasts literally like 5 months now and I barely use it. The nozzles seem to be spraying properly at my windshield. I look under the soaking hood insulation and see dried crusty windshield washer fluid. Is there any way to get rid of the stupid heated fluid as it is useless in my situation. I heard the 89 w124s didn't have it and it is a serious fire hazard.
W124
'89 did have it. You could just replace the hoses and disconnect the nozzle heater wire. That should take care of the leak and avoid a smoking engine compartment one day very soon.
1995 E320 Sedan
So I should just leave the coolant heater pipe in my windshield washer resivoir? Also where exactly do I unplug the nozzle heater wire?
1995 E320 Sedan
bypass that heater element. Just pull the whole thing out and toss it.
OK I'm being stupid I bet, but how exactly do I bypass it? there is this coil which coolant flows through into my reservoir and then there are wires and pipes in my hood that go to the nozzles, why do the nozzles have electricity in them if the washer fluid is heated?
Join the 2 hoses that at the top of the coil element, thus bypassing said coil.
The purpose of the coil is to keep the windshield washer bottle from freezing and breaking.
The nozzles are electrically heated to prevent them from freezing when the windshield washer function is activated
1995 E320 Sedan
Thanks for telling me how to bypass those hoses, do you also recommend unplugging the nozzles in the hood completely?
Just leave the nozzles in place unless you want to see 2 holes
1 - 9 of 9 Posts
