2009 E350 4Matic
I noticed that my windshield cleaner nozzle doesnt work. I mean is shoot fluid but extremly weak from one side of one nozzle so weak that strea dont even reach the glass. I suspect that rubber gasket on top of the windshield cleaner tank got inside and clogged hose or something else. Sounds like pump is working as I can hear it and everything worked after I add fluid last time than next day no action Can anybody advise how to fix this thing?
Thanks in advance
Burbur
2009 E350 4Matic
Discussion Starter #2
Forgot to mention it is E420 1994 but I guess it shouldnt be different system than other models
W124 Moderator
The nozzel is clogged. Get a needle and clean it out, spray, clean, spray. Use the "eye" end of the needle to adjust the angle of the jet. Yes, they do swivel inside the nozzel head much like a jet in a spa.
Good Luck
Jayare
