Hi New to the forum,
I have a C 200K Estate 2003 i found washer fluid leaking from the rear driver side. I used the filler in the engine compartment, and next day was totaly empty. Is the reservoir in the engine comartment or is there some tank in the rear of the car. Could it be a hose that has split, (we have extreme weather currently in Scotland), does anybody know how to access the area to check.
Any advise welcomed:bowdown:
1987 560SL - 1994 S420 - 2005 S55 AMG
Hi Keith, could be the grommet / o-ring for the wash pump or the pump itself. Unfortunately the o-ring doesn't hold up well if you pull the pump to inspect it. The o-rings are cheap. Best to dry everything and fill it up and inspect where the leak is. Use a flashlight. Should be very visible if it all leaks out in day. Does the pump work when you refill the tank?
