Or they do close but as soon as I open a door it goes down about 10-15 cm.
I know that it is supposed to go down a little but not that much.
Its the same on Both sides of my clk 230 coupe kompressor -00
Does Anyone know how i can fix it ???
Skickat från min iPhone med Tapatalk
Have you tried anything yet?
I would start with disconnecting the battery and leave it for 30 mins, then reconnect and do a window re-set.
Yes that Ive tried.
I can close one Window of I dont open that door again but then I still have the other window that wont close....we tried to do a reading with obd2 och MB: version of obd2 but it didnt connect with the car ....Ive checked all fuses ..
1999 W208 CLK320
Just guessing,but it might be a faulty door control module.
Sometimes it's just simpler and more cost effective to get the fault diagnosed by a good MB independent specialist. $50/£35 spent now can save hours of head scratching and replacing parts unnecessarily.
Discussion Starter · #5 ·
Hawkwind thx for answers.
But it seems as my little car has decided to mess with my head as the Windows, since 2 days ,work perfectly as they should again, but the steering Wheel has started to shake when I reach 100 km/h instead .
1999 W208 CLK320
Glad the window issue has resolved itself.
I doubt the steering problem is related. Maybe you just lost one of the tyre balancing weights, if it started suddenly. Or perhapse there is some wear in the suspension.
Discussion Starter · #7 ·
Hawkwind I Went to the firm WHO change my tires and they Said they were very sorry that a newbie had change them for me as he had put them on wrong.... hopefully this Will resolve It self too now that they put them the right way...
