03' CL55 AMG
I have the 97' S600. When you open & close the door the windows should open about a half inch then when you shut the doors they close automatically, they don't any more. I was changing the tint on the windows and wanted the windows to stay fully closed, so I manually triggered the door latch with the doors open to make the windows stay close. After I was done, and released the door latch the windows will not work automatically anymore.
SEC 600 V12 2dr COUPE (RHD) One of the chosen few.
You need to reset your system.. Ignition key in position no 2 .. wind each window to the bottom..hold switch in down position for ten seconds.. then to the top and do same.. do all four from inside .. turn key off exit and..you should be back in control...
