1970 w109 6.3, 2014 ML350 (petrol) AMG kitted, 2004 Vito 115 crewbus, 2003 CL600 V12 bi-turbo
Hi V fans,
I have a December 2004 Vito 115 crewbus and the passenger side window won't stay closed without trying it several times. It goes up then acts as if it hits an obstruction at the very top - then goes down again.
Is there any adjustment for this or setting arrangement. How can I fix this?
Any help would be really appreciated.
Vito 115cdi 2005
Make sure the window is clean. Spray some WD40 in the guides that the window runs in. If all else fails try to reset limits as follows - close window by holding switch in and only releasing 5 seconds after window is closed, then open window and release button only 5 seconds after it stopped.
Mercedes Vito Dualiner 2005
mine done this the other day... i just had to do it manual... but it did not close to the very top...
then it came back to life and has been back ever since
it happened thanks to someone closing the door while I was putting the windows up... bloody women.
