I have a 91 500 SL. The passenger window stoped working. I tracked it down to the switch by removing the plug and could make the window work. My question is what is holding the switch to the console? I can only lift the bottom of the console @ 1 IN.
Hi I think after removing my console recently they push out but I would advise you remove the console and dont pull it up as they very expensive to replace:( and removing it is not too bad a job and to get the switch back will be easyer :thumbsup: hope this helps
