E320 Yr 2000, S430 YR 2002
I have just replaced the assembly with the Windows, mirror , ESP and trunk switches because the trunk swiitch was not working. It looks like the trunk switch body is cracked, so does not allow the little button on the electronics board to be pushed to make contact. The body is the "rocker switch like" piece about one inch long with the small car shape drawn with the trunk open. It also has the very small lens for the red LED that shines when the lid is open. The switch body is the part that is broken. It has the following numbers in small black raised letters POM/C and 53602. Does anyone know if thsi piece can be replaced without buying the whole assembly at about $450 from EBAY ?
1990 Mercedes-Benz 420 SEL(RIP),1997 Mercedes-Benz E420
press your key to pop open the trunk to ensure its not a vacuum hose leak.
I have replaced the switch and the new switch works fine, so I think the vacuum is OK. However, I want to replace the small trunk switch so that I can have a spare unit.
