1989 w124 260 E
On my 89 260e the window made a funny noise when it got to the top so I took off the door panel to check it out and I see that the big gear that the motor moves is missing a couple of teeth at one side. My question is can I replace just that gear or do I have to buy the whole system. Also where is the best place to buy this? Thanks.
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
the motor and drive gearbox can be removed but the gears are plastic in the gearbox so if your missing teeth on the steel part i would just got to the boneyard and get a full replacement. My plastic gear drive(plastic for noise reduction) box stripped not the steal teeth and i replaced just the gearbox for 1 dollar.
I have the same issue with the missing teeth on the metal gear on my 1994 E320. Anyone knows the parts number? Is there a DYI for this?
