Hey Guys. I have a problem with my 1985 coupe 300CD turbo diesel power window. The window on the drivers side will only go up about 3/4 way up and start to slip/skip. I have to pull it up the rest of the way. I tore the door panel off last summer and couldnt really tell because the frame work was in the way...Has anyone else had this problem? Im wondering if a gear is slipping or a tooth broke. Thanks for the help BTW not very mechanically handy.
1985 300CDT, 87 300DT
Turbo300
Got a problem that's similar with my 85 Coupe. Was told it is the regulator, which is not going to be cheap. Have a quote of $411 to fix ($278 for the part, $133 for labor). I'm on the hunt for a cheaper fix, possibly a used regulator. What sucks is I replaced the same regulator just about 5 years ago! This may be your problem, hopefully something easier though. Good Luck.
-Joshua
My coupe is doing the same thing, sigh.
^^Thanks for the link, yet I believe the OP was referring to the front drivers window, that's where my problem is anyway.
