84 190D
Hey,
my drivers front and pass rear windows don't work
fuse is intact 12V through it
~11V at power sites of windows
i assume motors are dead...
i have replacements but how to roll the windows down to replace them? and unbolt from the motor
1989 560 EUROSEL 1984 190e8V 2000 e320 sport
you could probably see it better when you take off interior trim pieces very simple just wtch you dont snap the clips on back.. when you have those out you will see how the motor is mounted i believe they have pins on the doors you just have to watch when you put new motor in i remember i had a problem with binding
84 190D
no ive taken the panel off but i cannot get the window motor to go up/down...as if it iss seized or somehting...it doent just free spin...
1991 190E 2.6 Auto, Artic White/grey MB-Tex
I had this same problem a few months ago, BUT both window motors worked fine. I *think* I checked the fuses and they were okay, so it went like this for a few months. Out of the blue, I decided to check the fuses again. I saw one that controlled the front driver/rear passenger windows and it was blown. I replaced it and they have continued to work.
