Hi there everyone. I will keep this brief incase it has been asked/answered before. The sliding clip (part #126 720 0042) in the track of my R/R window has busted, How do I get the new one on the regulator, the nub on the regulator arm is larger than the hole in the clip? Any help in this matter would be greatly appreciated.
that's the one
That is the part i am talking about, however I have been unable to find any decent instructions on how to attach it to the regulator arm
1990 420SEL, smoke silver/tobacco
remove the regulator from the door, it's easy. grind the peened end off the nylon slide, and remove from reg. arm. install new slide in hole, peen end over on a suitable anvil, reinstall in car. ~ 1 hour.
1985 380 SEL
If you are minus an anvil I popped the back off the plastic bushing, removed the metal rivet and replaced it with a low profile 1/4-20 - 1" bolt, washers, and nut.
