1998 E320
I was changing out the motor mounts today and I disconnected the battery at the access panel below the rear passenger seat. When i reconnected the battery, the windows did not work hardly at all. I mean all four of them and the sunroof. They SLLOOOWWLY go down, halting most of the way, and sloowly go back up in 1/4 inch increments to close. Same with the sun roof.
any ideas? new time for a battery ir something more expensive??
thanks.
· W210 Moderator
99 E320
have you checked the STICKIES, specifically referencing the numerous
RESYNC steps, tried them all, and it still performs as you've described?
if not, do that (those) first, then report back.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
Yep, it's all covered in your owner's manual.
