Mercedes Benz
How do you put the window back on track because it fell outta the track and when i roll the window it doesn't do nothing. How do i fix this?
90 300 SE ,85 300 GD
Take off the door panel
Remove the door panel. Start by removing the screws that hold the armrest. Then remove the plastic cover on the doorpull. Remove the doorpull mechanism with one srew. The panel will lift up slightly and then pull off. You will see the window at the bottom of the track. If it is merely off the track, you can carefully realign it and try the motor to see if it is aligned properly. It is VERY EASY TO SCRATCH THE GLASS!!!! Be very careful and us a piece of wood if you must pry the window channel. If it is no readily apparent that the window is just off track, let someone help out. The window is $50 used from the junkyard. Be sure the motor is not burned out while you have the panel off. Hope this helps!
