G
I have a 2001 CLK320. I have a lot of wind noise from the driver's side window, as if the seal is not tight. Does anyone else have or has had this problem?<p>cs872557-a.mtnk1.on.wave.home.com
G
Discussion Starter · #2 ·
i had this problem w/ my 99' 320. i had the...
seals changed on both the driver side window/door pillar and sunroof. this helped a lot but imo the mirrors themselves need a redesign. they create a lot of windnoise. this was all under warranty btw.<p>adsl-63-203-99-41.dsl.lsan03.pacbell.net
G
I have the identical problem, but mine is worse:(
When I close my driver side door it sounds like the window is loose, or something is (bad sound, sometimes the door will not close unless you slam it). And when I wash my car w/ a high pressure spray, the water gets inside the door. I'm going to take it to the dealer sometime soon and will keep you posted!<p>
G
Noise are coming from the mirror gap...no noise from from slk mirror because there's hardly any gap.
<br> I don't know why on my Clk mirror there's a big gap.<p>pixie.chulavista.lib.ca.us
G
Discussion Starter · #5 ·
Re: I have the identical problem, but mine is worse:(
My problem is exactlt the same.<br> I took it to the dealer, and they adjusted the door and the window, and it was better (still not perfect) for a few days. Now, It's back again. I have another appointment on Dec 3 with the dealer again. Hopefully they can fix it.<p>cs872557-a.mtnk1.on.wave.home.com
