At 40mph+ I can hear a slight wind noise from my driver door (towards front) which annoys me like nothing else. When I push the window out slightly it stops. Obviously the seal is not perfect but I'm wondering if anyone has had this problem and how they fixed it?
Thanks.
I had a similar issue. I started noticing that I could hear wind noise on the driver's side. It became progressively worse, until one day I closed my door and the window rattled. I opened the door and grabbed the glass. I was able to lift the glass about 2 inches. So I took the door panel off and sure enough, the bolts which clamp the glass to the guide were loose. Tightened them up and all is better.
