These wheels may or may not work. The D93's on the S420 W140 are usually 9×18 on all 4 co...
These wheels may or may not work. The D93's on the S420 W140 are usually 9×18 on all 4 corners. For the CLK C208 you will probably want to do 8×18 front, and 9×18 rear. You will also need different mounting hardware as the W140 uses an ET43 application with 14×1.50 lugs and the C208 uses an ET32 with 12×1.50 lugs.
