1987 560SL
1997 SL500- 40th Anniversary
^^^ The important metrics for your stock setup is
7x15H2 ET25 5x112
7" inch wide rim, 15" diameter with a 25mm offset. 5 bolt at 112mm spacing. Bolt seat is not chamfer, but a radius Rim is hub-centric, but I forget size...
Compare and you're all set.
edit found hubcentric dia... 66.5mm
82 380SL 96 SL500 03 SL500
Probably not, but you'll need to know the wheel width and ET to be sure.
It appears by reading the ad that the seller doesn't have a clue.
1989 560 SL
I was also looking for rims at a local used shop - put a 17" on and they did fit my 89 560SL. I'm 99% sure that they were the same wheels from the same car your looking at. He wanted $1000 for them. I took a pass - just looking for some beaters for the winter myself. I found some at a local junk yard off an '87. If you are looking for a nicer set, that junkyard did have a set of 4 chrome 15# OEM's. Google M&M Auto Recyclers in Stafford, VA. They ship.
R/C107 Moderator
Mr. Z posted some specs.
I believe the specs are:
17" x 7.5" 36mm offset (front)
17" x 8.5" 34mm offset (rear)
Proper ET for a set of 7 1/2" wide rims on a 107 is around et18.
So if the rims are et36, 18mm or so spacers would be required, along with the proper length bolts.
