300CE - 24
Hey guys! I've got one q
Will these Cerwin-Vega HED 5, fits the original places...?
My Car 300CE-24 from 90
Frequency Response:
40 Hz - 20 KHz
Power Handling:
40 Watts (MAX)
Nominal Impedance:
4 ohms
Sensitivity:
87.1 dB
Dimensions:
Mounting Diameter
4-1/2" (114mm)
Mounting Depth
2-1/4" (57mm)
Height
n/a
Width
n/a
http://www.cerwin-vega.com/products/mobileaudio/hed2/hed5.html
91' 300E
Generally your entire system need to be rewired when swapping in newer speakers. The impedence of the original system is 8 ohms or 2 ohms, and new speakers run on 4 ohms like you posted, so if you are running a new head unit the difference in impedence will cause the deck to turn off. Those look like they would fit in physical size but you might run into problems with the impedence.
