5 mm is not really significant, it depend on tire size. 215/55/16 probably OK, 225 or higher might rub on the front. you can try mount it on and spin it if it not rubbing anything it should be OK, make sure you try with full turning left and right. How wide's the rim, does it come with tire, you probably see what tire can go on in the chart earlier.
