ive been offered a set of kahn rsc 20" wheels for my cl they came off an sl500 the front offset is 31 and the rear is 28 fronts are 8.5" wide rears are 10" wide will these fit or foul the arches as the car is lowered any help would be great.
sl500 wheels onto cl500
sl is post 2003 r230 chassis and cl is 2001 w215 chassis my original wheels are 8.5 x 18 with 245/45/18 tyres and the other wheels are 8.5x20 with 245/35x20 tyres for the front with et 31 offset and the rear wheels are 10x20 with an et 28 offset and they have 275/30/20 tyres i can put on narrower tyres just want to check they wont foul my fenders as the car has been lowered by app. 1" thanks for any help you could give me
Mercedes Tires and Wheels
Tire sizes look good however the offsets are a little low for your vehicle. According to my guide you may have some clearance issues with the fenders. You may be able to roll the fenders to keep them from rubbing but that would be entirely up to you. We recommend a 35-40mm offset for the 8.5 on the front and a 35-40mm offset for the 10" rear wheel as well. That said the rear wheel may stick out about 1/4-1/2" not counting the tire and the front may be flush-1/4" sticking out not counting the tire.
The Post 2003 SL500 needed very large brake clearance so I don't think there will be an issue clearing the brakes on your CL500.
Hope this helps.
2003 CL600 Renn Tech,1987 300 D Turbo
Hi I'm about to do a similar swap on a cl600. They guy has a set of 19" brabus replicas that are 8.5 front that seem to fit OK 9.5 in the rear and it looks like the rim sits flush with the rear quarter but it was hard to tell with no tire on the rim offset was 37 mm. These cars have a hydraulic suspension that if it fails at the valve block she drops to the turf and takes out the fenders if they stick out too far so i need to be sure. I test fit the bare rim on it and it was looking border line but without the suspension sitting with a load on it the camber may have pushed the rim out further than it would set loaded down with a tire on it. Decisions, Decisions any help from the forum would be greatly appreciated. Stockers are the 18 inch six hole Maybach type with a 44 offset. Thanks for any replies.
