My cls 500 (M.Y.2006) will remain parked for about 3 months (at average temperature 5-10 °C). Besides disconnecting the battery pole and tire inflation to max pressure, is there anything else I should do to keep my merc ''healthy''?
I would rather hokk it up with a smart charger than disconnect the battery, if it's possible where you park it. Disconnecting the battery could give you problems when starting again.My cls 500 (M.Y.2006) will remain parked for about 3 months (at average temperature 5-10 °C). Besides disconnecting the battery pole and tire inflation to max pressure, is there anything else I should do to keep my merc ''healthy''?
I agree. Leave the battery hooked up so the electronics and remain happy and active. Hook up a "smart" trickle charger.I would rather hokk it up with a smart charger than disconnect the battery, if it's possible where you park it. Disconnecting the battery could give you problems when starting again.
Popular Fuel Stabilizers:I have read about the ''stabilizer'' in other similar to this topic posts. I suppose it's a chemical additive, isn't it? Do you have in mind any specific product that you suggest I should use?
