SL500, ML320, E320
BRETT:
Generally, yes --they are interchangeable. If you use the search feature in the forum you can see some of the other discussion on the matter. A few postings indicate that some minor adjustments may be required- don't know if that might be US vs. European models or the "panorama roof" model in particular.
But 1990 to 2002 should all be appropriate for your car.
Regards-
1990 300SL, 2004 E320
Panorama Top Fit
I too have a '90 300SL and I installed a '98 Panorama Top from a '98 600SL. There was no modification needed. Latching mechanism, windows, electrical defrost extension plug, weather stripping all fit without incident. It is a tested rainproof and carwash dry fit. I've read other threads of misfitting and where there was a weatherstripping problem causing leaks. I wondered, before I purchased, if I was going to be running into problems. I just purchased and hoped for the best. And I have no regrets on my decision as those glass tops are fantastic.
Hz[8D]
